주요 콘텐츠로 건너뛰기
2012년 9월 12일에 발표된 여섯 번째 Apple iPhone입니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 검정색 또는 흰색으로 제공하였습니다.
2522 질문 전체 보기
Black screen pinging sound when on charge.
Hi,
I recently managed to revive my daughter's water damaged iPhone 5, but it was suffering with intermittent signal problems and after replacing the screen, it wasn't responsive all the time.
I bought another iPhone 5 that had a damaged logic board, but "all the other parts worked".
Using the guides here, I removed my daughters logic board and put it in this other phone.
Now it won't turn on, and when plugged into the charger, it just pings every few seconds. The screen does not light up.
I thought that I might have damaged the screen flex cable, but both the screens I have, have been tested on another phone and they both still work. I have slao tried both batteries in the phone but still no luck.
I am going to strip it down again, but apart from the screen connector and the battery connector is there anything else I should be looking for?
Thanks
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 3개
가장 유용한 답변
Stuart, water damage is the toughest of repair since one never knows which components have failed. In your case you at least know your LCD is working. That would leave the backlight coil, backlight IC and the filters on the logic board. These parts are very small and will require a great deal of practice to solder. If you think you would like to tackle this kind of job, post a couple images of your logic board so we can point the components out to you. I would need a good picture on the LCD connector and just below it. there are three small components that you could check as well. sorry, I do not have a good image of that particular area.
L3 is a 22UH-20%-0.38A-0.876OHM VLF302510T-SM coil
D1 is a NSR0620P2XXG diode is a SOD-923-HF package
U23 is a LM3534TMX-A1 backlight IC
Also, when you clean your board, make sure that you remove the EMI shields.
Hope this helps, good luck.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Oldturkey03,
Thanks for your response. I am not really competent at soldering, but I have a friend who is.
I will disassemble the phone again today and try to get some pictures for you to look at.
Thanks
댓글 달기
Hi there a pinging noise mean the the display is damage but saying as you have used two working screens then the problem could be on the lcd connectors on the motherboard itself
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Con,
I have looked at the connectors, and they were slightly corroded in one area, so I have cleaned it with electrical contact cleaner, but it has made no difference.
Thanks for your time.
댓글 달기
It's because of your logic board.
When it comes to water damage, it's nearly impossible to have everything salvageable without a new logic board.
Does the phone produce a lot of heat without the screen being on?
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Dylon,
What puzzles me is that the logic board and screen were working before I put them in the other phone body. I can only assume that I have damaged something while transferring the logic board to the other phone.
Like I said in the previous posts, I have cleaned any corrosion off the contacts, tried both batteries I have and both screens. The only thing I haven't done is put the original rear facing camera back on the logic board, but I wouldn't think that the camera could cause this issue.
Thanks for your help.
댓글 달기
귀하의 답변을 추가하세요
Stuart 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 2
전체 시간: 2,967
