주요 콘텐츠로 건너뛰기
5세대 iPhone. 수리는 간단하며 스크루드라이버, 비집는 도구 그리고 인내가 필요합니다. GSM/CDMA / 16, 32, 또는 64 GB / 검정색 또는 흰색.
2193 질문 전체 보기
little inductor broke off logic board, not the blue coil
hello,
2 little pieces have broke off the logic board.
They're located here
and the little one next to it
could that be the reason i can't get a signal?
keeps searching or no service..
Could it be soldered back on and if yes, what are the names of the inductors?
thanks a lot
Updated image
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 4개
saartje de prijck, your images are a bit to blurry to properly identify your components. Any chance you can post clearer images?
thank you so much :)
0[image|344932]
is this one better?
i know but i had to resize them :/
Thank you for accepting my answer. Sorry, I could not see your image:-)) I added it to the original question since Comments does not allow you to add images.
댓글 달기
답변 1개
선택된 답변
saartje de prijck, your images are a bit fuzzy:-) See if this will answer your question.
U3_RF is a RF1642 in a QFN12 package
U21_RF is a 824-2170MHZ filter in a 0402 package. It appears to be one of Murata's "Chip Multilayer LC Filters (BPF)". Something like this most likely.
c46_RF is a 6.3V 10UF 20% capacitor in a 0402 package
Yes, it is possible that these missing components are part of your problem. Hope this helps, good luck.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
saartje de prijck 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 321
