주요 콘텐츠로 건너뛰기
The CyberHome CH-DVD 300 is a 480p progressive-scan DVD player that is able to play DVDs, MP3s, and CDs.
Why is the disc tray not ejecting?
The DVD player is on but when I press the 'Eject' button nothing happens.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 5
댓글 달기
답변 2개
가장 유용한 답변
The disk tray is not ejecting because the motor may be damaged. Also, the disk tray may be off track from the mechanism that allows it to slide forward and backwards. For more information, refer to CyberHome CH-DVD 300 Troubleshooting
이 답변이 도움이 되었나요?
점수 1
댓글 달기
It's complicated to tell you but I found the tray won't open because the motor metal center is attracted more over time to the magnet piece in the top part that keeps the disc from spinning off, What to do is you take off the cross plate and you cut out a round piece of masking tape to put on the motor center, so that it is covered, then you put the cross plate back on to test if the tray will open. Add another layer of tape to lesson the magnetic pull, so the motor can drop down and the tray will open.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Aydee Melgar 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 4
지난 30일: 24
전체 시간: 2,148
