주요 콘텐츠로 건너뛰기
Repair guides for Android cell phones manufactured by Sony Mobile and Sony Ericsson.
1302 질문 전체 보기
Why is the display not working on Sony Ericsson Xperia Pro MK16I?
I have a Sony Ericsson Xperia Pro mk16i. Once it was dropped by me and since then the screen doesn't waked up. I went to a repair shop and they told the phone is on, may be the sheet has cut. Then I used the hdmi cable came with my phone, connected it with a television and yes the screen was there at my television screen. When I touched the phone screen it was working, and I got to know that display only is not coming. Now my question is what is the reason, and what is to be replaced? How much cost and time it will take? I am from India.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 5개
선택된 답변
aksstorm89, either your LCD ribbon cable got disconnected or your broke the LCD. You will have to disassemble your phone and take a look at the LCD ribbon cable. Make sure it is properly connected. If it is, replace the LCD. Cost for that is anywhere around $50 and looks like about an hour of your time. Hope this helps, good luck.
해당 답변은 도움이 되었습니까?
점수 2
댓글 3개:
whether if cable is disconnected I have to replace whole lcd
and thankyou sir for the reply
If the cable is disconnected, reinsert it. If it is connecting but LCD not working, replace LCD. Thank you for accepting my answer.
댓글 달기
hey askstorm89, how long after u bought the phone did this issue come in? My Xperia Pro's display has exactly the same problem :( My phone is 2 years and 1 month old. And, did u get it fixed? How much did it cost u?
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
the only thing what working in mines is just screen brightness but no text since it fell down
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Hi xperia pro starts up with blank screen
Answer:change its flex cable buy it from aliexpress.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I also have same problem after I dropped my phone,
I changed both flex cable and display but but still the display not working but whole the phone and touchscreen works as I can receive call by sliding,the phone switch also works well.
Pls help
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
aksstorm89 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 3,257
