주요 콘텐츠로 건너뛰기
2011년 상반기 모델, A1278 / 2.3 GHz i5 또는 2.7 GHz i7 프로세서.
782 질문 전체 보기
White Screen, nothing else
Just got an old Macbook Pro from a friend which stated the screen was all white and nothing else but the chime.
Verified the white screen and nothing else but that. Tried to clear with CMD+P+R but didn't help, still only the chime (once) and randomly turning off the computer.
Opened it up, checked cables and everything looked OK.
Tried booting it up without the battery - the backlight on the keyboard started working, but nothing else.
Replaced the RAM-modules (2x2GB) with 2x4GB, same with the old harddrive, replaced it with a Samsung EVO 840 120GB.
Nothing...but the white screen.
Plugged in the Mavericks USB install whilst having the harddrive unplugged...after about 30-40 seconds I heard a voice which was familiar from the installation guide.
But the screen is still all white.
Any ideas why this is - and how to resolve it?
Sincerely,
Fredrik
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 2개
가장 유용한 답변
A white screen usually indicates a hard drive issue. I don't know what was on the Samsung drive. The first thing I would do is replace the Hard Drive/ IR cable with a new one.
해당 답변은 도움이 되었습니까?
점수 2
댓글 5개:
The original drive which was installed when I got the Macbook, is an old Hitachi 320GB drive (manufacted february 2011).
Could a faulty HDD/IR cable really cause my problem? Seems kinda far fetched. :)
That's why I'm the Mac Professional and you're not. I now keep 6 of these in stock as the problem is so prevalent. See this question: Using new hard drive cable in older machines 821-1480-A
How can I see what kind of cable I need? I only have these numbers... Model NO: A1278 Serial NO: C2VFD1M4DH2G
Apple MacBook Pro "Core i5" 2.3 13" Early 2011 Specs
Identifiers: Early 2011 13" - MC700LL/A - MacBookPro8,1 - A1278 - 2419* Hard Drive cable part#Apple Part #: 922-9771, 821-1226-A
MacBook Pro 13" Unibody (Early 2011-Late 2011) Hard Drive Cable A bad cable can destroy the hard drive also.
Thanks alot for your help, I think I'll order one and see how it goes. But, I can't imagine a simple HDD cable can turn the screen white and make the computer turn off randomly...it just doesn't make sense.
댓글 달기
its an hdd problem and an ir problem fredrik it was 2011 when made don't u see?
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
Model NO: A1278
fredrik model number dont count these days now its searial number plese give serial number then i can tell u wat the problem is.
댓글 달기
귀하의 답변을 추가하세요
Fredrik 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 3
전체 시간: 845
