주요 콘텐츠로 건너뛰기
Buick Century is the model name used by Buick for a line of upscale performance cars from 1936 to 1942 and 1954 to 1958, and from 1973 to 2005 for a mid-size car.
36 질문 전체 보기
Replace broken radio console on 2000 Buick Century?
I have a buick century 2000 and the cassette player broke so i would like to replace the whole radio console with a newer sony console the new console comes with a frame to make it fit into the buick but i can't seem to find a tutorial on how to get to the radio to take it out
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 1개
선택된 답변
mark, you will have to remove the dash panel for that. There is a single screw located under the fuse panel on the end of the dash, remove that. Then just carefully pull out the plastic dash, it is only held on with some pushpins. Remove the 2 screws holding the radio, and unplug the wiring and the antenna. Then you can remove the radio. You could check on here. Check this video as well as this one. Here is a regal dash, but same idea Follow the partially, just the part about removing the dash. That should help you to accomplish the task. Hope this helps, good luck.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
mark 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 2
전체 시간: 2,886
