주요 콘텐츠로 건너뛰기
Samsung Galaxy Note II는 대형 스크린과 필수 자체-저장 스타일러스로 최적화된 소프트웨어가 결합한 스마트폰입니다.
After changing the LCD, Phone is not working
Please help me.
I just fix my LCD screen from some store, and they fix it by 240$. Then, I tried to turn it one but there is no response from the phone. It doesn't work at all when I connect the battery, but after I connect the Charger (Power Supply) It gives the sign for charging and battery level. But when I try to turn it on, it is not working.
Before I fix the phone, everything is working good. Please Help
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
please help!!!!!!!
댓글 달기
답변 4개
선택된 해법
http://m.youtube.com/watch?v=Gre9qaJyCZw
Try this
이 답변이 도움이 되었나요?
점수 0
댓글 달기
You need to let if charge up for 10 minutes or so before it will turn on
이 답변이 도움이 되었나요?
점수 0
댓글 10개:
I changed the phone LCD, from the phone fix store. But, they said that I need to do some software set up, and they did not know how to do it.
The problem with phone after they replace the LCD that when I turn on power, I'm getting no response. not turn on, just black screen without any thing. My Question when I plug in the charger, it gives me the sign for charging and then disappear. and return to BLACK screen for long of time, PLEASE HELP!!
Bring the phone straight back to the shop that was supposed to repair it and demand they get it turned on .. Was the phone working when u left it in?
Yes, it was working FINE, but after they changed the LCD, it is not working.
Do u Know What is the PROBLEM ?
The PHONE is Not Working, Can U explain for me WHY????
Well the lcd seems to be working as the battery logo coming on screen sounds like the power button is broken..
댓글 5개 더보기
댓글 달기
Hi,
I just fixed note 2 screen. Every thing was fine before closed every thing I put battery to make sure every thing was fine. After that I put back panel or cover(over mother board) of the set and closed every thing then I put battery but phone is not getting turn on.when I remove the back cover it works perfectly... I am just wondering what happen every thing is fine with out back mother board panel.
Thanks
Umar
이 답변이 도움이 되었나요?
점수 0
댓글 달기
After replaced my LCD samsung my phone is doesn't work my screen shot? What happened do I need to turn back to the repair shop?thanks I hope u reply
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Joseph 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 8
전체 시간: 699
