주요 콘텐츠로 건너뛰기
2012년 9월 12일에 발표된 여섯 번째 Apple iPhone입니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 검정색 또는 흰색으로 제공하였습니다.
2522 질문 전체 보기
Problems after power button repair
Power button was giving problems (no other problems with phone) so called a iphone repair service and they came and replaced the power button/cable thing. Power button works fine now but speaker no longer works and the power is draining rapidly (won't hold charge). They came back and said not sure why and would try to find out and get back with us. Now one day later my camera won't work either. What did they do wrong on button repair that has caused this and how do i fix it? help please as i have lost confidence in them
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 1개
Would I not be better off to let someone else correct this? are you saying probably need a new battery and motherboard now because of mishandled repair? Would rather have it fixed quickly, but I am new to all this. Considering this has been three visits. Only charged me once, but still......
댓글 달기
답변 2개
선택된 답변
Battery drain is caused by a damaged or bad battery or damaged components on the motherboard by prying the battery out and not sure why the camera has stopped but could be either a faulty camera or it's the motherboard.. Looks like they really did a number on you.. I would leave phone back with them and demand it get fixed
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
You would need to find a reputable company that does good repairs there is a woman on here called Jessabethany and does alot of motherboard repairs and would sort you out and tell you the problems
댓글 달기
Sounds like you may have multiple problems--
It is possible that all of these problems *could* be caused by greasy pizza disease---the technician assembled your phone and transferred finger oils that are interfering with electrical contact necessary for some components to work. Rule out by having them clean and reassemble the phone.
The battery drain problem could be serious---the iPhone 5 has somewhat of a sensitivity of the U2 ic chip that controls the logic of the charging system. In many phones it becomes damaged after unrelated repairs---that one is difficult to fix, but battery drain problems must start with new battery and new dock connector.
It is entirely possibly, probably in fact, that an inexperienced technician or someone working too quickly has inadvertently knocked off some components on your motherboard in multiple places. This is repairable, but you'd have to send the motherboard out for repair.
Honestly, it sounds like this shop needs to give you a new phone, while they take yours and figure it out. I would ask them for a lender iPhone 5 and restore it from a backup.
good luck!
jessa
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
kim 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 2
전체 시간: 110
