주요 콘텐츠로 건너뛰기
Samsung의 5-세대 Android-기반 Galaxy 스마트폰은 2014년 4월 11일에 출시되었습니다. 이 휴대폰은 지문 스캐너, 최신 카메라, 대형 화면 및 방수 기능이 개선되었습니다. 네 가지 색상으로 제공됩니다; 검정, 파랑, 흰색 및 구리.
577 질문 전체 보기
질문 마감됨
galaxy s5 change screen display
Hello my girlfriend's phone just fall down and the screen is like crap.. I m thinking to buy a lcd display and replace it I saw that it's easy but I want to know something the glue that is between the screen and the mid case exist at the new original screen? If not what I have to do? Thank you
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 4개
가장 유용한 답변
iliasnikolaou23, I am not sure about the "easy replacement" :-) You should have enough adhesive retained on the midframe to keep the display glued. If not, and that is what I d in some cases, add a small amount of rubber cement to the areas. I do stay away from "Gorilla Glue" as well as crazy glue. Hope this helps, good luck.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
Any samsumg screen that comes as just a screen and needs glued is not original as all genuine samsung screens come with frame attached
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
That was for the s4. I want to buy glass with display glued. That I asked if exist glue at the glass ornot
Good question actually. I am wondering the same thing.
댓글 달기
I just did a replacement for it on my shop, is fairly easy to take the broken screen, if you carefully heat up the screen and remove it slowly, you may actually leave the original adhesive on the frame. also when pulling up, watch out for the sensor button, since the flex cable is right behind the lcd, which mean it stick to the back of it. Other than that it was simple to take out
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Here is a very good tutorial walking you through how to step-by-step replace a cracked Galaxy S5 display http://www.etradesupply.com/blog/how-to-...
Please kindly note: Samsung Galaxy S5 comes with the new water resistance performance. However, if your Galaxy S5 suffers breakage and need to be repaired, you have to be aware of some non-reusable parts that must be replaced to the new one when reassemble.
These parts are:
Galaxy S5 front housing adhesive / form tap
Galaxy S5 Bracket Cu tape
10 screws on the middle frame
3 screws on the rear housing.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
The screws need replacement to keep the phone waterproof?
댓글 달기
조회 통계:
24 시간 전: 2
7일 전: 2
30일 전: 2
전체 시간: 5,648
