주요 콘텐츠로 건너뛰기
모델 A1278, 2012년 6월 출시. Turbo Boost가있는 Intel 프로세서, 최대 512 MB DDR5 비디오 RAM
1624 질문 전체 보기
Will replacing the upper case fix my problem?
Two days ago, i spilled coffee on my macbook pro. I knew that I had to dry it out, so I tried to open it up to take the parts out, but I couldnt do that because I could not find a screwdriver small enough. So I then spread rice over the keyboard to soak up any moisture that might have gotten underneath. This seemed to work, because afterward my mac turned on and everything was like normal except for the trackpad, which was stuck. So I left the rice on it a few more hours, and after that the trackpad was working much better, though certainly not as well as it did before.
But a few of the keys no longer work on the keyboard, and I was wondering if replacing the upper case will resolve this issue?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 1개
The keyboard cannot be replaced on the 13" model, it requires an upper case replacement ;-(
댓글 달기
답변 1개
가장 유용한 답변
Unfortunately, the answer is maybe. Replacing the upper case is not an easy repair. Have a look at this guide if you are thinking of doing it. Read through all the steps so you get an idea of what you are getting into. Whether this would fix the problem depends on how much liquid got into the guts of your machine and how far it went. You won't know that answer until you open the case. If the liquid is only in the keys and track pad you may be in luck and the repair should fix the problems. On the other hand, if you find the logic board and other components covered in sticky residue you may have corrosion happening in the connectors between parts. If you want to give this repair a try read this guide too. If liquid got all the way down into the little connectors, turning on and using your computer before doing a thorough cleaning may be encouraging more corrosion. So if you think you are up for the repair do it sooner rather than later and leave the computer off until you can do the cleaning.
iPhone 이미지
안내서
Repairing iPhone Liquid Damage
난이도:
어려움
1 - 2 hours
MacBook Pro 13" Unibody Mid 2012 Upper Case 이미지
안내서
MacBook Pro 13" Unibody Mid 2012 Upper Case Replacement
난이도:
어려움
1 - 3 hours
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
laura 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 6
전체 시간: 630
