주요 콘텐츠로 건너뛰기
Model A1311 / Mid 2010 / 3.06 및 3.2 GHz Core i3 or 3.6 GHz Core i5 프로세서
342 질문 전체 보기
How can I test the Power Supply (voltage values)?
I have an iMac (Model A1311, EMC: 2389) that won't power up properly. I want to test the power supply but cannot find the output voltage values anywhere on the internet.
I would be happy to post a 'technique' article showing people how to access and test the power supply in this model if someone can help me determine their proper output values.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 18
댓글 2개
Bless you, bless you, bless you both! The link led to a trove of excellent technical material and the diagram you posted is very clear. Thanks! I WILL post a technique article on testing this PSU so that others following in my footsteps will have an easier time.
Thanks again, and may the Valar watch over you! - Valdaquendë
That would be fantastic and help a lot of others!
댓글 달기
답변 2개
선택된 답변
This PDF should give you the pin out: Apple Technician Guide for iMac (21.5-inch, Mid ... - tim.id.au
http://tim.id.au/laptops/apple/imac/imac...
해당 답변은 도움이 되었습니까?
점수 13
댓글 10개:
Thanks again for that link, mayer; it's probably the biggest, most comprehensive archive of manuals for Apple devices I've ever seen! Apple devices cross my workbench with some frequency but it's been varying degrees of hard to find the manuals needed to work on them.
I should add that the site contains manuals for thousands of other laptop models by many different manufacturers; anyone reading this who has a frequent need for this sort of material will find the site a wonderful trove of information. Thanks again!
This PDF works to iMac 21,5" Mid 2011 (EMC: 2428)?
I don't understand the down vote on this.
@mattgordon see above request for explanation of down vote
댓글 5개 더보기
댓글 달기
Valdaquende, just in case you miss mayer's link
해당 답변은 도움이 되었습니까?
점수 10
댓글 2개:
Thanks! This pinout was just what I needed. I accepted mayer's answer because it contained the info I needed and TONS of additional information but I wish I could have split the answer between the two of you; both answers were very helpful. Thanks again!
Valdaquende, that is the proper choice. mayer did answer the question appropriately and I just wanted to augment his answer. Well done.;-)
댓글 달기
귀하의 답변을 추가하세요
Valdaquende 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 4
7일 전: 18
30일 전: 87
전체 시간: 31,539
