주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Lenovo IdeaTab A2109는 2012년 8월 27일에 출시된 9인치 멀티터치 스크린 태블릿입니다.
Why isn't my volume button working?
My volume button isn't responding when I press the button. My tablet will not let me adjust the volume using the button on the side although I can change the volume manually on settings.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 2개:
If it's anything like mine, you need to press the Fn button at the same time as F1 F2 F3
Bcohen has the answer...atleast it worked for mine. Thank you
댓글 달기
답변 1개
This is a fairly common problem, and has two solutions to it.
First, try resetting the tablet. Occasionally the button becomes unresponsive, and you just have to reset the system and it works again. To Reset the system, you will enter System Settings and then Backup & Reset and you can press on Reset and the system will be resetting to the initial state.
If this does not work, you will have to replace the Digital Board inside your tablet. Follow the Lenovo IdeaTab A2109 Digital Board Replacement Guide.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Abigail Bertholf 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 20
전체 시간: 8,651
