주요 콘텐츠로 건너뛰기
An easy to use home Espresso machine created by Saeco and rebranded for Starbucks. This machine is excellent for every day espresso drinkers and has an excellent build and product life.
140 질문 전체 보기
Ready light does not come on
The Ready light does not come on anymore. The water does not get hot. The pump does work. Water does come out of the steam dispenser & brew head. I did feel the brew head & it was slightly warm, but never got hot & the ready light never came on after 10- 15 minutes.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 2개
Is it under warrenty?
No, it is not under warrenty. It is probably 5 or 6 years old.
댓글 달기
답변 4개
가장 유용한 답변
What barista model do you have???
is it this one?
"normally" - the problem you are describing is the result of a calcified or defective boiler.
if it's the model as shown in the teardown, than you can also search for parts from the Saeco Estro Vapore - it's the same machine
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
If the machine is warming up somewhat but not getting hot then your heating element is probably coated in calcium. You should be descaling roughly every 3 months to prevent this from happening; make sure you use a proper descaling agent (Dezcal/Durgol) as home remedies such as lemon juice or vinegar are not good for the machine.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
If you’re handy with a few simple tools, replacing the boiler sounds like a good option. Certainly, try to clean it first, but replacement isn’t a tough job either. Read the guides on Ifixit, and search on youtube videos. Parts are pretty common on Ebay, sometimes you can buy a machine just for parts pretty cheap. Just chop shop out a boiler and reinstall it.
Sometimes you get REALLY lucky. I bought a brand new Starbucks Barista SN006, in the box, for $150. I almost fainted when I saw it. Now my old one is is slowly but surely being repaired and cleaned, and my wife isn’t bugging me to fix it!
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Mine won't start at all replace start button cord is good.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Nora Neese what model is yours. Starbucks Barista xxxxx? Besides the power cord, what have you checked?
댓글 달기
귀하의 답변을 추가하세요
Ken 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 4
7일 전: 11
30일 전: 25
전체 시간: 3,055
