just doesn't pump water out
my GE washer/dryer stacked combo model # WSM2700HAWWW ... the washer runs, spins fills with water, washes , just doesn't pump water out... is the pump the problem?
좋은 질문입니까?
좋은 질문입니까?
Hi
If it ran, spun and then filled with water again it is not the pump. It worked after the first spin.
이 답변이 도움이 되었나요?
In my experience, Most of the time a sock or something small will slip past the inner tub and into the pump
what i'd do is use a Zip-tie to block the waterflow from the full tub, remove the clamps, hoses off the pump. look inside and pull whatever it is out. if the impeller is visibly busted its time for a new pump
이 답변이 도움이 되었나요?
지난 24시간: 1
지난 7일: 7
지난 30일: 29
전체 시간: 951
