주요 콘텐츠로 건너뛰기
모든 Apple 휴대용 태블릿 컴퓨터의 포괄적인 수리 설명서. 많은 경우 수리는 열처리와 조심스럽게 비집어 열기가 필요합니다.
5765 질문 전체 보기
질문 마감됨
After replacement of screen, it keeps getting loose
Hello there,
I have tried replacing the screen on two different iPads (iPad 2 and iPad 4). The same thing happens everytime, after some time (from ½ hour to a week) the screen goes loose in lower left corner.
This is due to the digitizer cable pushing up on the screen. But I cannot seem to figure out how to avoid this ?
I have watched several videoes and really taking note on how the cable is located at disassembly but no matter how good I "tuck" it in, the cable seems to "go loose" when I lay the glass on the iPad.
What do you do to avoid this?
Thank you in advance!
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 3개
가장 유용한 답변
Hi there this is a common mistake in laying the ipad glass down the cable should not be folded under and resting on the glass it fits down that little gap it's coming out off..
When taking the old screen out replicate the folds and bends it's a tricky part to get right ..
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Not only is "the tuck" of the digitizer cable extremely important (especially on the iPad 2), but a good quality adhesive kit is also key. I found these guys last year, and will never go back to standard adhesive kits:
http://bowlertech-adhesives.com
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Thank you con and brianalt !
I did thought that the cable was actually supposed to fold a little bit under the glass, otherwise is quite difficult to sit with the lens in one hand, laying the lcd with the other and tightening the screws :-) But practice makes perfect I guess.
I have also tried ordering some bowlertech-adhesives to see if they are as good as they say. Looking forward to trying.
Thanks both of you!
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 8,708
