주요 콘텐츠로 건너뛰기
The Sony Xperia Z is an Android based phone that was released in 2013. It is one of the largest phones of the Xperia family with a 5-inch full HD display. Model numbers include C6603/C6602.
98 질문 전체 보기
Cracked screen with lower half responsive
Hi guys,
My Xperia Z was knocked on to wall with its corner.
And there's a crack inside the phone.
The outer glass/screen is not cracked, its the inside.
Cracked hairline area aren't responsive, but lower half ( non-damaged area is able to respond to touch )
I've seen the repair guide for XZ in this website, and the guy is only replacing one part ( touchscreen and lcd display? ).
I'm not sure which parts should I buy to replace the screen myself.
Front LCD Display Screen+Back Cover
Touch Screen Digitizer
Or should i get this full set, which is expensive?
[http://www.amazon.com/Sony-Xperia-Displa...|Full LCD Display+Touch Screen Digitizer
Or please advice on the parts.
Thanks.
Regards
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 2개
선택된 답변
fish, unless you have experience with that, I suggest the complete assembly. Yes it is more expensive but it will also make the job a lot easier. you are also less likely to break the parts and having to replace it a couple of times. Hope this helps, good luck.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
i would also recommend buying the lcd with the frame attached. it's $5 more for the frame and makes it look like new, the reason behind this is that you don't have to adhere the lcd back to the frame.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
fish 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 1,068
