주요 콘텐츠로 건너뛰기
이 안내서를 사용하여 모든 제조사 및 서비스 제공 업체의 전화기를 수리해보세요.
73575 질문 전체 보기
Remove stuck broken stylus from headphone jack?
need help in removing the piece from my phone don't know what to do help
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 5개
Could you descirbe the trouble you are having a little more in depth
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Hi, if it's a piece of broken headphone jack plug that's stuck in there then I have been able to remove them in the past using a 3mm screw about 20mm long.
Dab a small amount of super glue to the end of the screw, make sure you just get it on the end and not on the sides of the screw and put it in the headphone socket and leave it to dry for about 1/2 hour.
Carefully pull the screw out and whatever is stuck in the socket should now hopefully be on the end of your screw. Sometimes it takes a couple of attempts but have successfully used this method a few times now.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
You are a genius
댓글 달기
I have that problem with a DAT machine but the superglue method didn't work. Any other solutions?
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Use hard tweezers and easily put it out.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Using a power drill with the smallest diameter drill bit (about size of a pin), drill a very light hole into the stuck piece of stylus. Using a small sharp tipped wood screw, hand screw it with screwdriver into the drilled hole just until you feel it start to grab. Hand pull out the screw with the stuck piece of stylus attached. That’s what worked for me.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
wendy setzer 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 1,237
