주요 콘텐츠로 건너뛰기
The 7 inch third generation of Nook color tablets by Barnes & Noble, not to be confused with the 9 inch Nook HD+.
30 질문 전체 보기
Need a source for replacement battery.
I have searched for a replacement battery for the Nook HD to no avail. All that can be found are not for the HD. None have the 4000MHA, 14.8 Wh rating.
Does any one know of a source, other than B&N (who won't sell the battery) ?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 2개
가장 유용한 답변
jmbiii3, the battery number for your Nook HD is BNA-B0002. the battery appears to be available right here and here as well. Of course, always check with the vendor. If you are truly fixed on the 4000mAh you can check on here
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Thanks ! The battery in the HD is a 4000mAh and I would like to keep it at that rating. I'd order the one you mentioned last, but can't quite read the order info. LOL
댓글 달기
Here you go!
https://www.newpower99.com/SearchResults...
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
jmbiii3 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 2
30일 전: 3
전체 시간: 2,353
