Is there conductor on the ribbon wifi antenna for connect with case?
Hi. Recently I replace wifi antenna from my iPad2. During replacement I lost 2 small screws for hold wifi antenna.
So I just use adhesive tape to attach it to body and I finish replacement.
I check my iPad wifi strength with iPhone5 and iPad mini and i found my fixed iPad shows a little bit less wifi strength compare to other devices.
Is this iPad use it's rear panel it self to use as the antenna? Because I saw there is small conductor on the ribbon tiny wifi antenna.
Then I should buy lost screws and re assemble..
Thx in advance.
좋은 질문 입니까?
댓글 1개
I mean, if the wifi antenna dose not stick to the rear panel by screw, the wifi signal would be drop or not?
RedbullCow 의
