주요 콘텐츠로 건너뛰기
Power Macintosh G4는 Apple이 1999년에 출시하고 2004년까지 판매한 일련의 개인용 데스크톱 컴퓨터입니다.이 페이지는 M5183에 한정됩니다.
39 질문 전체 보기
Stays on Boot Screen and Nothing More. What can I do?
I'm fairly new to Mac softwares and hardwares.... 3 days ago I was gifted by a friend a Power Mac G4 Quicksilver and it didn't came with its peripherals, just the tower. Today I decided to plug it in to see what it needs to be updated and cleaned and when I turn it up it stays on the boot screen and doesn't do anything else, even doesn't show the loading spinning wheel. I unplugged it, pressed the I/O button, removed the RAM and the battery from the mother board, after 5 minutes I put both things back in and when I turn it on again it stays on the boot screen like the first time. I left it like that for some time now to see if it boots completely but nothing. Also I don't have the OS CD.
From what I could see on the mother board it has 3 128Mb RAM's and 2 40Gb HD's
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
You may have a hard drive ID conflict. Disconnect one of the hard drives and check the jumper setting. Set it either to Master or Cable select. You may have to do a web search for your exact hard drive and "jumper setting". Do this for both drives to see if it boots or has a system folder on either drive. Let us know your results and we can go from there.
해당 답변은 도움이 되었습니까?
점수 2
댓글 7개:
Thanks for replying and I made an error describing the model of the G4 I have. I own the Graphite (M5183) model and in the inside it has 3 256Mb Rams, 1 40Gb IBM Deskstar HD & the other one in the bottom is 80Gb Western Digital WD800 HD. I also notice that it had a multicoloured cable similar to the one connected to HD's disconnected and it has one conector only at the tip, could that be the problem? if not I will proceed with what you suggested.
First there are 28 different M5183 models. The hard drive sits on the bottom of the cabinet. Another hard drive can be stacked on it. It sounds to me like you have one installed in the optical drive bay. Here's where the hard drives should be: Power Mac G4 M5183 Hard Drive Replacement
Yeah exactly like that and found the exact model of my G4
http://www.everymac.com/ultimate-mac-loo...
Sounds like the previous user did not know how to set up Master- Slave drives, so he used the optical drive BUS for the second hard drive. Disconnect the drive in the upper bay and see if it will boot. Next switch out the hard drives and see if that one will boot. Set the drives to Master or Cable select.
I see well, I will do that then and comeback with the results. c:
댓글 2개 더보기
댓글 달기
귀하의 답변을 추가하세요
QUARAN7INE 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 4
전체 시간: 198
