주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
4세대 iPhone의 CDMA 버전. 수리는 간단하지만 앞면 유리와 LCD를 하나의 유닛으로 교체해야 합니다. 16 또는 32GB / Model A1349 / CDMA 호환성.
How Do I Make My Battery Work?
I dropped my phone down the stairs and the back came off. My phone still worked but I figured it needed a battery change- because we had already ordered a new battery since it had gotten wet a few times before. That battery did not end up fitting so I ordered a new one. My phone is an A1349 CDMA and I ordered a battery that said it was compatible with the A1349 but when I put it in and plugged it into my charger it didn't recognize the battery was there. The phone turned on but there was no service and no wifi- it was only turning on because the charger was plugged into it. I can tell because the phone does this with or without the battery as well as saying 100% and the battery should not be charged very much. The battery fits perfectly. The charger seems to work, considering the phone turns on. I can't go back to the old battery- it is past mutilation. I am wondering if the new battery is not working because the screw isn't in? Does it require the screw for it to work? Or is it because I accidentally broke something or messed something up inside?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 -1
댓글 달기
답변 1개
Faulty battery or maybe because u stated it got wet a few times also
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
No, the first battery got wet. That's why I replaced it.
I'd like to know why the NEW battery isn't working.
댓글 달기
답변을 추가하세요
Alley 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 4
전체 시간: 84
