주요 콘텐츠로 건너뛰기
A Nokia E-series smartphone with a physical QWERTY keyboard and Optical Navi Key. Successor to the E71. Released in 2009.
13 질문 전체 보기
Nokia E72 Motherboard is broken at bottom where it connects charger
Respected Sir,
I have a Nokia E72. And its charging connector part which is at the bottom of motherboard is broken and cut off. Sir, is it possible to fix this issue ?click to see the image
Yours faithfully
Murulimadhav
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
Murulimadhav, if it is broken off, you will need a new board. This is a multilayer board and with the part broken off, those circuits are interrupted. There is no other way to fix it. Hope this helps, good luck.
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
ok sir, thanks a lot i got it
can you tell me where will available the nokia E72 mother hoard .. i find almost all mobile shop in where i am working in ksa and also online but its not available...
댓글 달기
답변을 추가하세요
Murulimadhav 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 4
전체 시간: 992
