주요 콘텐츠로 건너뛰기
Second generation of CDMA iPad 2 with 16, 32, or 64 GB and Dual Core A5 Processor. Model Number A1397. Repair is detailed and requires heat and prying.
52 질문 전체 보기
shuts off when tapped in places other than the screen.
I started changing out a broken screen but messed up the antenna in the process. Got them both changed out thanks to IFIXIT. It seems to be ok except for one thing. When you tap the sides or bottom ever so slightly or set it down, it shuts off. After a few seconds, the apple appears like I restarted it or something. The battery was completely drained but is 80% now and still doing it.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 1개
sounds like the motherboard is not making good contact with the battery underneath. If you open it back up, tighten up the screw holding the board on the battery and that will likely solve.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Tyler 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 2
전체 시간: 712
