주요 콘텐츠로 건너뛰기
2009년 중반기 모델 A1278 / 2.26 or 2.53 GHz Core 2 Duo 프로세서 EMC 2326
745 질문 전체 보기
Corsair rams 4x2 (8G) 1067mhz
Hello guys.
I have purchased and installed my new rams corsair 8g 1667mghz
I would like to know my MacBook Pro rams was 1066mhz but now it is 1067 MHz is that okay or not I see lots of people using this corsair rams but I would like to knowledge myself and learn is it okay if the rams has a higher speed than the actual speed of the machine like 1066 mhz to 1067?
http://qkpic.com/15b0b
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 5개
선택된 답변
If your computer is working properly I would not worry about the difference between 1066 and 1067. My main concern would be does Corsair certify this ram for use in an Apple computer? If so no problem but if not it could cause system board problems over time. Ralph
해당 답변은 도움이 되었습니까?
점수 3
댓글 1개:
agreed +
댓글 달기
this is the link
http://www.newegg.com/Product/Product.as...
해당 답변은 도움이 되었습니까?
점수 1
댓글 5개:
Looks good to me. Ralph
outside of being a bit overpriced, looks good to me +
That ram is 1066, not 1067...
Well sorry brother but I am not the one who said 1067! it is written in the website + on the plastic box of the rams.
Gabe thanks so much for helping me in this post :)
Best 4g and 8g ram memories for MBP?
I am very satisfied with the rams ^^
댓글 달기
Thanks so much guys
Is there any thing I should do after I install the rams? like resting something pram or something like that?
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
댓글 달기
Guys anyone know why my machine temperature increased after using my new 8g rams? (with no Vmware ) with VMware it gets worse
the cpu is 80 centigrade and it goes to 70 if there is no lots of apps working.
note: I did not reboot my machine since 6 days because the machine looks quite fast and no need for refreshing memory.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
With this speed, it rounds, since technically the ram it running at 1066 and 2/3Mhz (.666666666_ Mhz) some companies/operating systems will round up, and others will round down, the ram is the same speed whether it says it is 1066Mhz, or 1067Mhz.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Thanks but can you answer my last question?
The machine gets hot very fast also the cpu above 70
댓글 달기
귀하의 답변을 추가하세요
Mohammad Fadin 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 3
30일 전: 4
전체 시간: 3,868
