I put new oil in my Lawn Mower now it smoking white
I have Cub Cadet riding lawn mower LTX1045
I was putting new oil in it and then started it up. It started smoking white smoke. I then checked oil level again and drained some out cause it was too full on the stick it said although I thought added under what the store even told me to add when changing the oil.
After checking level again I tried to start it. It would not start. It tried to turn over few times but then would not start at all. I am not sure what to do. Oil was in my air fliter so I ordered a new part to change it but I cleaned it up cause wasn't very much. I also ordered a new oil filter in case needed that. Should I try something else?
좋은 질문 입니까?
댓글 14개
Hello, I have the same issue with my Craftsman riding mower. It is spitting oil out of the muffler and out of the oil reservoir, also the white smoke. Could it be the head gasket?
mk1806 의
Yeah I have the same issue with my tb320 it’s blows white smoke . At first it’s blows a lot of white smoke out then the smoke just stops blowing while the lawnmower is still functioning . My question is it still operable to use while the smoke is still blowing ? Or should I just leave it alone for a bit ?
Robert Croissy 의
We have a ltx1045 spewing oil and white smoke when starting. No problem starting though and runs fine. But it is obviously leaking oil. What could be the problem. Thanks in advance for your help!!!!!
Judy ramsey 의
Mine is blowing white smoke and idling very high....
Chris McCarthy 의
You may need a new ring on the piston? Probably not sealing in the piston shaft.
David Sabjan 의
댓글 9개 더보기
