주요 콘텐츠로 건너뛰기
2013년 9월 25일에 발표된 Samsung Galaxy Note phablet 시리즈 3 세대. 모델 번호 N9005로 식별 가능.
248 질문 전체 보기
Camera on back takes blurry photos? can it be fixed
The camera on the back of my samsung note 3 always takes blurry photos, I have reset my whole phone and everything, it only started doing this a couple of days ago.. please give me some tips or let me know if I can fix it myself or I have to pay someone to fix it??
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 16
댓글 6개
i m facing same problem , all was well and suddenly next day my camera became blurry.it can focus nearby objects upto 15 cm beyond that pics are blurry .there is no scratch or anything.i m no more intrested in fuking samsung.....after this type of pics .........i m just waiting it to explode like note........
@atulkumar008 'm experiencing exactly the same.
my j7 prime back camera became blurry after i put it in a onsie pocket. this was a couple days before christmas. it is still blurry and i don't know how to fix it. there are no scratches on it. please help
I m a j5 user n same bloody problem
I find that the inside lens is dirty. I don't have the tool to open and clean it though.
댓글 1개 더보기
댓글 달기
답변 13개
가장 유용한 답변
Can you see visible marks on the glass that covers the camera? On my galaxy note the glass become marked, it happened quickly and it was almost like someone had dropped some super glue on the glass but I suspect it was that the glass was slightly raised out of the body and was being scuffed when you put the phone on say a table or desk. I was really careful with the phone as it was brand new and so can't think of any other reason. I could have sent it to be repaired but it would have been gone for about a month and I needed the phone.
What I eventually did to fix it was took some car scratch removing cream (cream that removes small scratches from car bodies) and rubbed that on the glass, it took a little while 20min of buffing but the glass slowly cleared and now photos are not blurred at all.
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
After repairing the broken SIM card base (GALAXY Note GT-N7000) at a local inexperienced shop, the back camera became blurred. After hitting the mobile by my palm, the camera recovered for a week or so. Later, it became blurred again. Despite thst I ordered the guy to re-open it for me ehere I cleaned the lens and the protecting glass with high quality lens cleaner.
Couldn't believe it how clear my camera become after hitting it few times.. Lol . Thanks Zuhairdhuwaib
댓글 달기
After panicking all day and then reading thru these posts. I eventually used a nail polish cleaner to wipe my lens. And voilà! !!! My pictures are now brighter and not blurry no more. Thank u all.
해당 답변은 도움이 되었습니까?
점수 1
댓글 3개:
this is very helpful. thanks a lot!
i just made my camera more blurry
was your camera just blurry ir did it have scratches. cuz mine is just burry and it didn't really work
댓글 달기
Hold 'capture' button until the subject comes in focus, then release the button.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Hey Jamie, here are some things you can try:
-Make sure camera lens is clean
-Turn on Anti-Shake
-Play around with the auto focus settings
-Hold the camera button (on screen) for a second, let it focus, and then release the button.
-Turn on Sports Mode
-Let me know how it goes
-Hope this helped
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Hello. I would suggest downloading a new camera app, but you did mention this problem only started a few days ago...you can go to or contact your local phone store and they will help you. I hope this helps.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
hi all. i was facing the same prblm... believe or not but seriously shook the phone for secs and bluredness of camera .. was gone... god bless india
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Hello all, I have the solution to this problem. I called Samsung and got someone who knew the solution. When taking the picture, HOLD down the 'snap'/'capture' button, until the picture comes in focus, then release the button. SMILES EVERYONE. ☺
Update (12/29/2017)
Select subject that you want to photograph
Hold down button
DO NOT release button, until subject is in focus
DO NOT TAP, KNOCK, BANG, SMASH, STOMP, OR ANY ACTION that could eventually cause more damage. Think about it, if you tapped yourself on the side of the head Every time you didn't operate properly, what do you think would happen?
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Hi, I hope this works for everyone. I was sold to HOLD the capture (shutter) button and the picture will focus. Hold the capture button until it takes the picture.
This has been the solution for me. They all should be the same.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Mine is S8 and i faced the same problem
Just tap the phone from behind 2-3 times gently
It worked for me
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
All I did to cure the problem of a blurry photo was, hold down the button and do not release it, until the tablet has brought the picture in to clarity.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
You could clean it with microfibre cloth and alcohol. Afterwards put a piece of scotch tape (clear) and press down to get into the smallest crack. It was recommended by a friend and it worked for my J1
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I just tapped my note 2 and its now working properly
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
pm me. i have discovered the fix just now. same here im using note 3.... https://www.facebook.com/brian.alegre.58
해당 답변은 도움이 되었습니까?
점수 -1
댓글 3개:
Brian, iam here now. Why do I have to go to Facebook to see your answer? You are using this site. Please just answer here. (I don't have Facebook)
I am facing same problem... my rear camera is not clear and have scratch on camera lens. What should i do?
Aftab pakistan mrnice786@facebook.com
댓글 달기
귀하의 답변을 추가하세요
Jamie 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 7
30일 전: 11
전체 시간: 62,051
