Replacing or upgrading cpu and how?
I have a Macbook 13" late 2008 model 2.0 ghz and it won't boot. I thought it might be the heatsink but it looks fine so does everything else. What happened was I tried replacing the dc jack unfortunately it wasn't the right model and all of a sudden the pc powered off and the fan would just run and run until the battery ran out. I want to try to replace the cpu but I want to know if it's possible with a heat gun? Also if it's a go instead of keeping my crappy 2.0 GHz processor how far up can I upgrade?
좋은 질문입니까?
댓글 4개
So I bought the 2.4 ghz logic board and am typing this from my laptop. Yes it is back to life.. But the bottom part won't close fully is that because?.. I'm worried if maybe it was my heat sink that needed replacement and if so should I not be using my laptop right now.. Would my laptop still boot even if there was a bad heat sink in it.. All in all this was an awfully expensive ordeal I think I spent close to or over 500 dollars the logic board was 280 canadian.
P.S. I ordered as well as 2 4gb of ram has been my long time dream to upgrade my laptops ram :D.
jpgarridolecca 의
Sounds like you got a different series board if it does not fit cleanly (the one designed to fit your case). I would talk with the seller to get the correct board. As to trying to force fit it by swapping out the heat sink: I don't think that is wise and it may not work either as the mount points could be different and the hight of the heat sink may not be what is holding things up.
DanJ 의
I upgraded to 2.4 ghz the heat sink fits cleanly onto the board. The laptop runs smooth it's not the i can't close it I can it's just bulging out a bit.
jpgarridolecca 의
where is it bending? That is what is different between the old and new logic board. If the logic board was for the same series case (Unibody MacBook5,1) this would not be an issue.
DanJ 의
