주요 콘텐츠로 건너뛰기
2004년에 소개되었으며 2010년에 단종된 20", 23" 및 30" LCD Display.
99 질문 전체 보기
intermittent flickering on cinema display
I have a 30" cinema display that intermittently will start flickering lines like crazy.. Here's a video demonstrating the problem:
http://tinyurl.com/nnc8toj
I am wondering if anyone has seen this before, and if it is the power supply? I don't want to spend $200 on a new 150w HD power supply if that's not the problem......
Thanks.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 3개
that flickering looks like bad caps
Does anyone know where I can find instructions on how to open this model up? It's the 2006 LCD 30" version... Every link I go to on google that looks like it might be instructions turns out to be dead.
댓글 달기
답변 2개
선택된 답변
I have same problem its not the monitor cable, ive checked this as I have dual monitors and psu's, swapped monitors same flicker on the one powersupply A1097 90w
Update (04/08/2020)
Yes just got a replacement powersupply supply on ebay and works correctly.
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
So the power supply was bad then!
댓글 달기
Have you checked on a different display?
If you see the same flickering on a different display it traces back to your video cables or the CPU/VGC. I'd try that test first.
If this answer is acceptable please remember to return and mark it.
해당 답변은 도움이 되었습니까?
점수 0
댓글 3개:
Well, this flickering happens with both my macpro and macbook pro.... I can't swap cables with the monitor because it appears the cables are permanently attached (unless I am missing some secret way to unplug them?)
What I meant was to plug the computer into a different monitor to ensure that the problem was with the display, not the computer. Having the problem with two different computers pretty much points to your video cables or the display. The only way to be certain you haven't damaged the cable is to replace it. Cheaper and easier than replacing the caps if that is the problem.
Does the video cable/connector look worn? Also try a different AC power cord.
댓글 달기
귀하의 답변을 추가하세요
patrick3 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 7
30일 전: 31
전체 시간: 3,053
