주요 콘텐츠로 건너뛰기
2006년 11월 북미에서 출시된 Wii는 인터넷 연결을 직접 지원하는 닌텐도 최초의 가정용 콘솔로, 온라인 게임과 Wii 숍 채널을 통해 게임 및 미디어 애플리케이션의 디지털 유통을 모두 지원했습니다.
286 질문 전체 보기
Wii USB port 0 not working, flip connections with port 1?
It seems my WII USB port 0 (the lower one) stopped working. Unfortunately i can't understand if it's a mechanical problem (burnt connector cable) or a USB controller chip problem.
Anyway, since Wii's USB ports are used for different purposes, and i don't need the port 1 while i really need port 0, I thought to somehow flip the USB connections.
In this way the Wii will recognize as port 0 the upper port and not the lower.
Do you think is possible to make such a fix?
In no step-by-step/teardown guide here i found about the opening of the USB connectors box. Has anybody of you tried that? What problems could i incurr in?
Any idea/hint is welcome
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
가장 유용한 답변
opening and soldering anything in the usb connectors box??
don't get me wrong!!
but since you're asking this question - i would highly recommend that you don't touch the usb connectors box and/or the mainboard.
i've seen many bad soldering jobs and most of them where the results of questions like this one. if you knew how to work on those parts properly - you would'nt ask that question!
the safest way is to give it a professional wii service/modding company, but since the part looks like a standard computer part, maybe there are others too that would do the job.
but to answer the question - sure - someone who knows how to do those things could do the port switch.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Alberto 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 3
30일 전: 9
전체 시간: 8,898
