주요 콘텐츠로 건너뛰기
Model A1199 / 2, 4, or 8 GB capacity
85 질문 전체 보기
iPod nano was washed and then turned on is it trash?
My daughter left her iPod in pants pocket. I washed it and my older daughter found it. They turned it on the screen lights up but wont play.
Is there any hope for it or is it parts now.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 2개
My daughter did the same thing. After gnashing teeth for a little bit, we just forgot about its existence until I happened to plug it in after six months or so and it worked (and still works) fine: it just needed enough time to dry out.
Both of us were ecstatic!
Mine took about a year and three months, then finally started working again.
댓글 달기
답변 1개
가장 유용한 답변
I would get some electronics cleaner or some isopropyl alcohol (>90%) and a soft paintbrush.
use the logicboard guide to disassemble the iPod.
clean everything "odd" looking (white/greenish residue) with the IPA and the paintbrush.don't forget the dock connector. let it dry - reassemble it and try to power it on.
if it wont power on, try to charge it - it could be that the battery got discharged while the whole whashing/cleaning process
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
Mcihele 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 2
전체 시간: 2,040
