주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
iPod Nano 2nd Generation Logic Board Replacement
필요한 것
    1. iPod Nano 2nd Generation Logic Board Replacement, Case Assembly: 1 단계, 이미지 1개 중 1개
      • Before opening your iPod, ensure that the hold switch is in the locked position.
      댓글 쓰기
    2. iPod Nano 2nd Generation Logic Board Replacement: 2 단계, 이미지 1개 중 1개
      • Carefully insert an iPod opening tool in the seam between the metal casing and white plastic top.
      • Lift the top bezel off the iPod. It's glued on using a mild adhesive, so some force may be required.
      댓글 쓰기
    3. iPod Nano 2nd Generation Logic Board Replacement: 3 단계, 이미지 1개 중 1개
      • When removing the bottom bezel, be sure not to bend the plastic surrounding the dock connector.
      • Carefully insert an iPod opening tool in the seam between the metal casing and white plastic bezel.
      • Lift the bottom bezel off the iPod. It's glued on using a mild adhesive, so some force may be required.
      댓글 쓰기
    4. iPod Nano 2nd Generation Logic Board Replacement: 4 단계, 이미지 1개 중 1개
      • Remove the following two screws:
      • One #00 Phillips screw with a large head near the headphone jack.
      • One #000 Phillips screw with a smaller head near the side of the iPod. This screw strips easily, so be sure to press down firmly on the screwdriver.
      댓글 쓰기
    5. iPod Nano 2nd Generation Logic Board Replacement: 5 단계, 이미지 1개 중 1개
      • Use a metal spudger to carefully pry the headphone jack out of the casing. DO NOT remove the headphone jack from the iPod entirely, as it is connected via a fragile ribbon connector to the click wheel.
      댓글 쓰기
    6. iPod Nano 2nd Generation Logic Board Replacement: 6 단계, 이미지 1개 중 1개
      • Slide the headphone jack out until the white plastic housing is no longer held in place by the metal casing.
      댓글 쓰기
    7. iPod Nano 2nd Generation Logic Board Replacement: 7 단계, 이미지 1개 중 1개
      • Remove the newly-revealed Phillips #00 screw from beneath the headphone jack. Be careful, this screw is easily stripped.
      댓글 쓰기
    8. iPod Nano 2nd Generation Logic Board Replacement: 8 단계, 이미지 1개 중 1개
      • Lift the bottom bezel bracket out of the iPod.
      댓글 쓰기
    9. iPod Nano 2nd Generation Logic Board Replacement: 9 단계, 이미지 1개 중 1개
      • Remove the two Phillips #00 screws from the top of the iPod.
      댓글 쓰기
    10. iPod Nano 2nd Generation Logic Board Replacement: 10 단계, 이미지 1개 중 1개
      • The highlighted connector attaches the click wheel and headphone jack to the logic board. This cable must be disconnected from the logic board before continuing.
      댓글 쓰기
    11. iPod Nano 2nd Generation Logic Board Replacement: 11 단계, 이미지 1개 중 1개
      • Use a spudger to disconnect the headphone jack cable from the logic board. You need to gently pry the connector toward (or up, if you like, the connector is like LEGO® building blocks) the front of the iPod until it comes loose from the logic board.
      • Special hint for the reassembly: Push the connector inside until it is over the corresponding connector of the logic board. Then insert a thin tool over the connector and push it down onto the logic boards connector.
      댓글 쓰기
    12. iPod Nano 2nd Generation Logic Board Replacement: 12 단계, 이미지 1개 중 1개
      • Use a spudger to push the logic board through the iPod out of the casing. The click wheel and headphone jack should remain in the iPod.
      • Be careful not to catch the headphone jack and click wheel on the logic board as you remove the logic board and display.
      댓글 쓰기
    13. iPod Nano 2nd Generation Logic Board Replacement: 13 단계, 이미지 1개 중 1개
      • When removing the logic board, place the tip of the spudger into the hole where you removed the screw and gently push it out. The crevice will keep it in place and decrease the chance of you damaging your board.
      댓글 쓰기
    14. iPod Nano 2nd Generation Logic Board Replacement: 14 단계, 이미지 1개 중 1개
      • Completely remove the display and logic board from the metal casing.
      • When reassembling, ensure that the battery is well seated. If the fit is too tight, the edge of the display will score the inside of the screen window.
      댓글 쓰기
    1. iPod Nano 2nd Generation Logic Board Replacement, Logic Board: 15 단계, 이미지 1개 중 1개
      • Use a spudger to scrape away the black glue covering the three battery wires.
      댓글 쓰기
    2. iPod Nano 2nd Generation Logic Board Replacement: 16 단계, 이미지 1개 중 1개
      • Peel up the orange tape covering the three solder points on the other side of the logic board.
      댓글 쓰기
    3. iPod Nano 2nd Generation Logic Board Replacement: 17 단계, 이미지 1개 중 1개
      • Place the desoldering wick on top of the existing solder ball.
      • Place the soldering iron on top of wick above the existing solder ball.
      • Hold the soldering iron in place until the solder melts into the wick.
      • Repeat the same procedure on the remaining two connectors.
      댓글 쓰기
    4. iPod Nano 2nd Generation Logic Board Replacement: 18 단계, 이미지 1개 중 1개
      • Be careful not to scrape the metal rings surrounding the connectors off the logic board. If you accidentally scrape these off, you won't be able to reconnect the replacement battery.
      • Use a metal spudger to carefully straighten the battery wires. Be sure to only touch one contact at a time.
      댓글 쓰기
    5. iPod Nano 2nd Generation Logic Board Replacement: 19 단계, 이미지 1개 중 1개
      • Pull the battery wires through the logic board to free the battery. If the wires don't easily come free, make sure the wires are straight and all the solder has been removed.
      댓글 쓰기
    6. iPod Nano 2nd Generation Logic Board Replacement: 20 단계, 이미지 1개 중 1개
      • Use a metal spudger to carefully pry the metal bracket off the back of the display. Make sure you only pry off the bracket and not the clear shielding on the rear of the display. By working from the inside of the display, you won't be able to accidentally pry up the clear plastic shielding.
      댓글 쓰기
    7. iPod Nano 2nd Generation Logic Board Replacement: 21 단계, 이미지 1개 중 1개
      • Peel up the orange tape covering the display ribbon cable.
      댓글 쓰기
    8. iPod Nano 2nd Generation Logic Board Replacement: 22 단계, 이미지 1개 중 1개
      • Use a spudger to flip up the black plastic tab holding the orange display ribbon in place. The tab will rotate up 90 degrees, releasing the ribbon cable.
      댓글 쓰기
    9. iPod Nano 2nd Generation Logic Board Replacement: 23 단계, 이미지 1개 중 1개
      • Slide the display ribbon out of its connector and lift the display off of the logic board.
      댓글 쓰기
    10. iPod Nano 2nd Generation Logic Board Replacement: 24 단계, 이미지 1개 중 1개
      • Logic board remains.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 12명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
iRobot
회원 가입일: 09/24/09
1 평판
안내서 636개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 17
지난 30일: 74
전체 시간: 40,933
