주요 콘텐츠로 건너뛰기
2.26 또는 2.4 GHz / 흰색 플라스틱 유니바디 인클로저
645 질문 전체 보기
back panel rubber fix
Hi,
I had upgraded to 4 GB of RAM successfully. However, while fixing the back panel back, I realized that rubberized coat had come out in some places. Now I can't fix it back the way it was before. Any help with this would be highly appreciated.
Ashwini
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 2개
선택된 답변
Update: I did it successfully. It was rather easy. All one needs is the smallest flat-head screw driver... the one that is available in a Dollar Store as a set with bunch of other star-head and flat-head screw drivers. After opening the back panel, drove the screw diver on the edge where rubber and aluminium panel meet and Voila... it came up and sat over the edge... Additionally, I applied super glue to keep it there. However, my advise is, if one has patience and it done all right with just the screw driver enabling rubber sleeve to fit on to aluminum panel, just leave it that way. This gets the job done as neat as the factory supplied one when the MackBook was new. The cost... None.... And Apple people were trying to scare me with all the big and shallow talks of warranty void and etc.... and huge sum of money in case the back panel needed replacement.
해당 답변은 도움이 되었습니까?
점수 4
댓글 3개:
+ well done
thanks for the tips Mr. Pandey
.... I was unsure about how to perform this task, because I did not know that someone had done this before with success.
... after reading your post, I took the screwdriver and super glue and managed to solve the problem of white rubber mac.
B Rgds!
댓글 달기
https://supportform.apple.com/201105/
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Ashwini K Pandey 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 2
전체 시간: 6,976
