주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
차세대 Nokia 기기 중 첫 번째 모델이자, 1080p 화면과 쿼드 코어 Krait 프로세서를 탑재한 최초의 기기입니다.
it's it possible to replace the front facing camera
it's it possible to replace the front facing camera?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 1개
I had the same question. The cable became damaged during a screen replacement and I found the replacement camera. Just not sure if its glued on or soldered or some other method. Any tips would be appreciated.
댓글 달기
답변 4개
가장 유용한 답변
Use can use these videos.Its really help me a lot for changing my camera.
https://www.youtube.com/watch?v=HQC2lZsB...
https://www.youtube.com/watch?v=qmNUl9Gh...
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
Neither video is for a 1520. one is for a rear camera and one is for disassembling the 900. Unfortunately neither have a similar front facing camera to the 1520. Did you replace the front camera on a 1520? Thanks for any help you can provide.
댓글 달기
Use 3m z conductive double sided band. 3M 9703
https://www.tedpella.com/TechNote_html/1...
이 답변이 도움이 되었나요?
점수 1
댓글 3개:
Also do not forget to heat 70 degrees C. otherwise it will not work.
Thank you!
But with this method. all the circuits of the camera you do not risk it to get in touch with each other?
The tape is conductive only for Z direction(vertically). Side by side contacts will not be connected. I did it and worked.
댓글 달기
Yeah, it's possible. Open the phone, find the broken front camera and replace it. But you must have bought the front camera replacement in advance.
이 답변이 도움이 되었나요?
점수 0
댓글 3개:
Do you have a guide our video that could show me how before I buy the part?
is there a guide or instructions. I can't tell if the front camera is glued down or soldered to the mainboard.
I have the same problem I have my camera replacement but not how to do it
댓글 달기
Hello,
I raise the subject, someone found a solution to replace the front camera?
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
bob 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 17
전체 시간: 2,407
