주요 콘텐츠로 건너뛰기
The Nerf Dart Tag Furyfire is a toy gun which fires rubber Nerf darts. It is equipped with a rotating chamber and pump-action barrel for rapid fire.
2 질문 전체 보기
Why are my darts not firing?
My Nerf Dart Tag Furyfire will not fire. What could be causing this issue?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 2개
If your gun is not firing, ensure that you have darts loaded in the chamber and that they are loaded properly. The barrel may be clogged, so check the barrel for any debris. The final problem may be that the large spring in the gun needs replacement. If the previous issues have been resolved with no success, open up the Nerf gun. You will see a large spring towards the top of the gun. Remove the spring for replacement. See our troubleshooting guide for more details.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
i can't remove the shotgun barrel at all even with tools
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Bradley 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 4
전체 시간: 1,541
