주요 콘텐츠로 건너뛰기
2010년 4월 출시 / 2.4, 2.53 GHz Core i5 또는 2.66, 2.8 GHz Core i7 프로세서
590 질문 전체 보기
질문 마감됨
How do I remove just the memory clips on the logic board?
I broke one of the two fasteners that secures the memory in the "down" position. Is there any way to replace just this part? I tried removing the 4 screws that appear to connect the fastener to the logic board but had not luck removing the piece. Any ideas?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 3개
선택된 답변
Not really possible ;-{
The issue is the pins that thread though the logic board and are then soldered in place. You need very special equipment to replace the RAM holders. Sadly, its time for a new logic board.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
Without removing the whole ram socket you can just cut the portion of the socket where the fastener is located and replace it from one salvaged from another scrap board.
Check this thread:
http://forums.macrumors.com/showthread.p...
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Might be S.O.L. On that one unless you can find a dead board that's identical to your board and are really good at soldering and unsoldering. You can try ghetto rigging it some how to stay down just be sure using stuff that is non conductive or anti static. And make sure you unplug battery while you are ghetto rigging it.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 436
