주요 콘텐츠로 건너뛰기
Cooler Master's mechanical gaming keyboard. Released with Cherry MX switches.
6 질문 전체 보기
Why is my keyboard not recognized by computer?
I plugged in USB cable into my computer, but my computer says that it is not recognized. It would be really awesome if anyone can help me with this by giving me some ways to solve this problem. Thank you.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 3
댓글 1개
Yeah mine started not connecting to my computer after 6mounths of use. It takes power from the usb so i can use it wireless but when i try to turn it on wired mode it doesnt work for some reason.
댓글 달기
답변 5개
선택된 답변
Try plugging it into a different USB port.
Check that you have the correct driver for it, it may not be installing the driver on its own.
Is it broken? See if it works with a different computer.
해당 답변은 도움이 되었습니까?
점수 3
댓글 달기
If plugging it into a different USB port doesn't work, try using a different USB cable. Your driver may also not be correctly installed; check this link for the correct driver. If it doesn't connect to your computer but connects to another computer, it's possible that the USB port in your computer has lost connection with the computer's motherboard; if so, you'll need to open up your computer and re-attach the internal USB cable with the motherboard. Search iFixit for instructions on how to do this with your computer. You can check the troubleshooting guide for your device for more information.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
The same issue with a Cooler Master TK Storm Stealth. I made the fatal mistake of buying it, because it was a cheaper mechanical keyboard, that only just after a year has started to malfunction. I could buy a much better CPU if I would buy an usual one, now it's to late. Cooler Master it's excellent in cooling devices, computer cases and power supplies, but have no idea howto make a reliable keyboard or mouse.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
The problem is the usb port on the keyboard itself. You have to dismantle the keyboard and solder the pins better. Had the same problem with my wacom intuos 4 too. Apparently robotized welding isn't meant to handle such forces of connecting and disconnecting at any pressure.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I have a Lenovo keyboards. It was working 100% Raeplaced hard drive. While loading drivers it bomb out on me and 3 days now. Cant get the keyboard to work?????
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Sukhyun Baik 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 4
7일 전: 26
30일 전: 99
전체 시간: 35,031
