주요 콘텐츠로 건너뛰기
Nintendo's first 3DS handheld device released February 2011, identified by model number CTR-001.
456 질문 전체 보기
What screwdriver should I use?
Hello there, I will be taking apart my 3DS ( Wifi card problems ) and I've been doing some research and it seems that the #00 Screwdriver which people recommend MIGHT strip the screws. Is this true? and if it is true what screwdriver should I use?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 3개
가장 유용한 답변
Alex, any screwdriver "MIGHT strip the screws". That is where the importance of good tools comes in. I prefer to use quality tools only, and invested in a set from here. The chances are slim to strip screws with the right set of tools.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
I used the smallest phillips screwdriver I had, and it worked fine but you have to press down firmly on them to make sure they grip tight enough without stripping.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
if it they arent coming dont force them. Apply a drop and i mean a tiny drop of oil (wd-40, pb blaster, trumpet oil, car oil, whatever). you need to let the drop of oil work in there for 20 seconds or so and try again. it is best to work the screw in and out meaning tighten and loosen it to get it free and even after its free you might have to tighten and loosen to work that oil in there. It will come out like this with patience
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Alex 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 4
30일 전: 6
전체 시간: 536
