Why is my Thrive not charging?
I have tried everything from buying a new charger to replacing the battery, but nothing works. What could the problem be?
좋은 질문 입니까?
좋은 질문 입니까?
It sounds like you have a possible charging port issue. Try replacing your charging port using the charging port replacement guide.
해당 답변은 도움이 되었습니까?
If you can find the stand. you can test to see if it is the charge port. The stand has a power adapter port built in. It has to be the stand with the HDMI port in it. I have found the batteries really need a power save app.
해당 답변은 도움이 되었습니까?
There is a resistor, possibly being used as a fuse, that goes out on most of these units. Replacing the resistor seems to solve the problem. If you can power / charge the tablet from the dock but not from the charge port, it is probably because of this resistor, rather than the charging port itself. I have repaired hundreds of these tablets with this issue. If requested, I will try to post a photo of the resistor in question.
해당 답변은 도움이 되었습니까?
Could you post a picture of this resistor and how to fix it? Thanks
Please post picture of resistor location for charger port for the thrive tablet, thankyou
Please post pic
Please point out resistor that acts as a fuse on power port board, this is for a Toshiba Thrive tablet.
thank you.
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 2
30일 전: 9
전체 시간: 2,147
댓글 1개
I have been having the same issue, though just yesterday I turned on the tablet and it was charged. I have quite a lot of Apps, and I began to wonder if low disk space could interfere with some software aspect of the charging/battery monitor process.
The Bridgefords 의
