주요 콘텐츠로 건너뛰기
The Acer Chromebook C710-2847 is part of Acer's line of low-price netbooks running Google's Chrome OS. The devices are simply constructed needing just one screwdriver to take them apart.
How do I turn my screen 180 degrees?
some douche at my school completley flipped my screen upside down and now it's practically impossible to us my chromebook.Please help!!!!
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 82
댓글 13개
It's quite simple. Use the keys ctrl+shift+refresh (The circling arrow on the top row) two times, it'll reset the screen back to 0 degrees. This is late, but just in case you need to know. If you can find a way to keep it at 0 degrees, that'd be awesome!
To set the screen in its correct (default) position:
Log in as admin -> hit ctrl, alt and the left aero (<-) beside escape.
...done.
Go into settings then display settings. Change screen to standard.
hi hi hi hi hi hi hi hi hi hi hi
Just flip it
댓글 8개 더보기
댓글 달기
답변 16개
선택된 해법
ctrl+shift+reload button
이 답변이 도움이 되었나요?
점수 57
댓글 17개:
this was so helpful the same happened to me and i have been stuck with it for two weeks thank you so much!!!!!!!
My attention seeking kitty changed mine :) Very helpful - It was tough doing everything with my head tilted lol
it was amazing
thank you!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
thanks to all u people
댓글 12개 더보기
댓글 달기
Just use the ctrl+shift+the reload button
이 답변이 도움이 되었나요?
점수 24
댓글 1개:
댓글 달기
Simply hit ctrl+shift+refresh. The refresh key is the one with the spinning arrow. It'll rotate the screen 90 degrees.
이 답변이 도움이 되었나요?
점수 20
댓글 2개:
it is still not working please someone help me "with no websites"
You are the best!! Thanks a million!!
holidayfun1943@gmail.com
댓글 달기
이 답변이 도움이 되었나요?
점수 16
댓글 2개:
not working for me
not working for me
댓글 달기
ctrl+shift+rotate=flip
이 답변이 도움이 되었나요?
점수 14
댓글 달기
On an acer chromebook you have to hit the ctrl key, the shift key and the refresh button at the same time and that's it! I've had this happen last friday and I called the kid a douche bag so when he saw this today he thought that I did it to get back at him or something I am not sure what he meant when he showed me but I do know when he did he kept laughing at me until he showed me so. I hope this was helpful. By By
April 25, 2016
이 답변이 도움이 되었나요?
점수 11
댓글 달기
Press ctrl shift and the refresh button at the top this will only rotate your screen 90 degrees so you will keep having to do it until your CB is back to normal
이 답변이 도움이 되었나요?
점수 11
댓글 1개:
omgg...THANK YOU SO MUCH
댓글 달기
hit the refresh butten.
이 답변이 도움이 되었나요?
점수 8
댓글 1개:
no this did not work
댓글 달기
이 답변이 도움이 되었나요?
점수 6
댓글 달기
You need to press CTRL + ALT and aero botton on your computer then it will make your screen default.
이 답변이 도움이 되었나요?
점수 4
댓글 2개:
thats for a different computer not chromebooks
What is the aero botton? Do you mean the arrow button? and if so, which arrow?
댓글 달기
All you have to do is hit these
three buttons simultaneously:*
ctrl
shift
reload
*at the same time
이 답변이 도움이 되었나요?
점수 4
댓글 3개:
it worked
yessssssssssss
Do you fix my Chromebook screen please
I need your help today
댓글 달기
bem boom bech bum italic text eat my big bum == Heading text == heck
이 답변이 도움이 되었나요?
점수 4
댓글 2개:
beembold text bom
i'm the douche heheh heck xd dab
댓글 달기
It's not working what button is the refresh button
이 답변이 도움이 되었나요?
점수 2
댓글 2개:
the circle arrow on top row on cromebook
circle arrow right besides the arrows
댓글 달기
Just yell Reeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee and it will flip back around
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
no don’t do that
댓글 달기
Would you fix my Chromebook today please
이 답변이 도움이 되었나요?
점수 0
댓글 달기
To fix your upside-down Chromebook screen, press Ctrl + Shift + Refresh (⟳) twice to rotate it 180 degrees back to normal. If that doesn't work, go to Settings > Device > Displays, then set the screen orientation to Standard. Your screen should return to normal!
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
isaiah Barnes 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 13
지난 30일: 78
전체 시간: 218,091
