주요 콘텐츠로 건너뛰기
The Acer Chromebook C710-2847 is part of Acer's line of low-price netbooks running Google's Chrome OS. The devices are simply constructed needing just one screwdriver to take them apart.
25 질문 전체 보기
I want to improve ram n ssd
Am Gabriel and i won't to change the 16gb ssd to replace it with the old original hdd it use to come with. I like my acer c710-2856. Also aquier propper info for a more powerful hdd that fixs in my acer perfectly. If it's possible for what am looking for is 2-8gb of Ram and 1 Tb hdd that would fit snug in my acer. Also with the modification i requested would it make my acer c710-2856 over heat.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 2개
가장 유용한 답변
You can add in one of the slim series of HD's (5~7mm in height). Leaving your SSD in place. As for the RAM the Chrome OS has a limit of 2GB. But you can enable Swap Memory. Follow this: How To Add Swap Memory to your Chromebook.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
BS alert on the answer above. The OS does not limit you to 2GB. I am running 8GB on my HP Pavilion Chromebook just fine thank you very much. I upgraded to 120GB SSD with no issues whatever. But I've not seen any affordable SSD's of larger sizes as of yet. You could get a 512GB one easily enough but it would cost ~$500USD. Just get a cheap magnetic external drive instead. Also neither upgrade had any impact on my chromebooks admittedly terrible battery life and it rarely ever turns on the fan either.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Gabriel Cespedes 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 4
30일 전: 4
전체 시간: 1,175
