주요 콘텐츠로 건너뛰기
듀얼 마이크와 802.11ac Wi-Fi 연결 기능을 갖춘 더 큰 Apple MacBook Air 노트북 입니다.
465 질문 전체 보기
SMC reset without power button
I watered my MBA a few weeks ago and it stopped working. After a proper cleaning procedure and replacement of the keyboard, it started working again but a few problems have arisen:
1) fans moving very fast and not quitting at all
2) power button not working
3) when fans are on, the MBA is very slow
I would like to reset the SMC in order to understand if I can reboot the system somehow; however, the procedure includes the pressure of the power button.
Is there any possibility to reset the SMC without that button as it doesn't work?
Thank you in advance!
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 2개
가장 유용한 답변
It is possible to jump start the machine. You will have to disconnect the keyboard and short pins.
If this answer is acceptable please remember to return and mark it.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
what does a jump-start cause? is it a total reboot or just a swich on of the machine? I read the link page and it seems just a boot of the MBA. I already disconnected the battery and the machine turns on every time I plug the power adapter.
댓글 달기
It is not a total reboot, it just turns on the machine. That said, unplugging the battery and the power for a bit (30 mins?) should accomplish an SMC reset.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
madmagazine 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 11
30일 전: 14
전체 시간: 2,332
