주요 콘텐츠로 건너뛰기
The Toshiba Excite 10 AT300 was released in mid 2012. It boasts a NVIDIA quad-core processor, 10.1 inch Gorilla glass display, and runs on Android 4.0 operating system.
Why is the sound not working in apps?
When I open some apps on my tablet, the sound fluctuates or does not work at all. I have checked the app setting and the sound is turned on. Is this a problem with the software or will I need to replace the speakers?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
선택된 해법
First, make sure that you check your tablets overall audio settings to make sure that sound is enabled and the volume isn't completely turned off.
When you try using the physical volume controls, does a volume status show up on the screen? If there is a " / " through the speaker icon then your tablet is stuck in mute. Try using the volume control to move the volume all the way up and then back down to toggle the mute icon.
If you don't mind doing a factory reset that would be your next step, to perform this follow the steps on How to Perform a Factory Reset. Be careful with doing this because it will wipe out all your data.
If this still doesn't work you may need to replace your headphone jack and speakers, the steps for these can be found here: Headphone Jack Replacement and Speaker Replacement.
If none of these solutions fixes the problem you may need to contact Toshiba directly.
Toshiba Excite 10 AT300 Headphone Jack 이미지
안내서
Toshiba Excite 10 AT300 Headphone Jack Replacement
난이도:
어려움
45 minutes - 1 hour
Toshiba Excite 10 AT300 Speakers 이미지
안내서
Toshiba Excite 10 AT300 Speaker Replacement
난이도:
쉬움
15 - 30 minutes
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Theresa Stewart 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 4
전체 시간: 1,809
