How do I replace a Burnt Out LED?
Only some of the LED's light up, how do I replace the ones that do not work?
좋은 질문 입니까?
좋은 질문 입니까?
The LED's can be tricky to replace. In order to replace an LED you will need to separate the circuit board containing the LED from the rest of the device. Using wire cutters, you will need to clip the broken bulb off and then solder a new one into place. The link below will take you to a soldering guide.
해당 답변은 도움이 되었습니까?
24 시간 전: 1
7일 전: 1
30일 전: 6
전체 시간: 1,145
