주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
모델 번호 A1238 / 80, 120, 또는160GB 하드 드라이브 / 검정색 또는 은색 금속 외형
My iPod is corrupted.
hi whenever i plug my ipod into itunes, it seems to be corrupted. I have restored it and all that jazz and it isent working, i have also tried to uninstal itunes but i dont think it really worked because when i reinstalled it, it had all the music in the library. help?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 -1
댓글 달기
답변 1개
frenchiekatie, the very first thing I would start with to clean the dock connector. Use some compressed air, isopropyl alcohol and a small non-metallic pick i.e. toothpick. Make sure that your pins are not corroded, bend or broken. After that, place your iPod into diagnostics mode and see what errors (if any ) you will get. To see how to place it in diagnostics mode and what the tests mean, check on here. Get yourself a USB-to-Zif adapter, disassemble the iPod using this guide. Check all your connections and make sure they are properly seated. If they are, remove the drive (if you have a USB-to-Zif adapter, try and access the hard drive with that. If your hard drive is accessible and the dock connector is okay, you most likely have logic board issues and may need to replace it. not a terrible job and most certainly not expensive. cheaper that a new iPod for sure. hope this helps, good luck
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
what are logic board issues? none of it seems to be working.
perhaps if i clear all the content of it it may work again.
댓글 달기
답변을 추가하세요
frenchiekatie 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 1,702
