주요 콘텐츠로 건너뛰기
The fourth generation of Honda Accord covering model years 1990 through 1993 available in coupe, sedan, and wagon chassis.
46 질문 전체 보기
How do I check to see if my valves are damaged?
My timing belt went out. A friend said if my valves are damaged it'll be more expensive than just replacing the belt. I want check to see if they are or not so I know for sure if putting on a new timing belt will be worth it.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 2개
Hi
Same problem in my 1990 Honda accord ex 16 valves. How do I check for valve damage?
What happened to your Honda? what engine size? what have you tried?
댓글 달기
답변 2개
선택된 답변
Nathan, to check the Valves you will have to remove the cylinder head. If the Valves got damaged then you nay also have issues with your pistons etc. If you need further information, give us the exact year and engine size of your Honda.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
가장 유용한 답변
A cylinder leak-down test should expose bent valves without having to pull the head. Buy or borrow a leak down tester, if excessive leak down is found, listen at the throttle body, the tail pipe, and the oil filler cap to determine if the air is going past intake valve, exhaust valve, or rings.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
Nathan 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 1,290
