주요 콘텐츠로 건너뛰기
네 번째 Google Nexus 스마트폰, 2012년 11월 13일 출시.
75 질문 전체 보기
Why my smartphone has huge bugs when it is not plugged in?
Hi,
My smartphone has several problems when he is not plugged in.
First time, it was when I used the camera in Vietnamese mountain. It was during the raining season and it was very very humid. The phone suddenly turned off. Since this day, when I use the camera, my phone frequently turns off.
I broke my screen for the second time. It was still there, with this very humid environment. Then, my phone started to have more and more problems.
Now, when my phone is not plugged in, it:
- turn off suddenly,
- does not found the GSM network
- ask several times the PIN code
- turn off again ...etc...
and now, these problems are almost permanent, but, I can use my phone normally without problem when I plug it in external battery or the mains supply.
I thought that could come from my broken screen... but I have changed it yet and my phone is still not working properly.
One more information, the first time I had fixed my phone screen, I did maybe some damages to the battery. The battery was very well stuck. I forgot to use the plastic tool. I use the screwdriver to lift the battery.
Do you have an idea of where this problem come from?
Do I have to change my battery?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
선택된 답변
indhy31, if you are still using the same battery, then I would absolutely change the battery first. You also want to make sure that you do not have any corrosion on the battery contact etc. Reevaluate after you changed the battery. Hope this helps, good luck.
해당 답변은 도움이 되었습니까?
점수 4
댓글 2개:
Hi oldturkey. Thank you for your answer. There is not corrosion on the battery or any where else in. As you suggest, I have order a new battery. I will receive in couple of day.
Hi Oldturkey. You was absolutely right! I have change the battery today and now everything are working well. Now, my phone is like new! Than you for your help.
댓글 달기
귀하의 답변을 추가하세요
indhy31 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 3
7일 전: 4
30일 전: 5
전체 시간: 358
