주요 콘텐츠로 건너뛰기
Released Pre-Fall 1997, identified by model number RM318PA
7 질문 전체 보기
Why does the projection clock "on" button keep turning off?
Whenever I turn the projection clock button to the "on" position, it moves back to the "off" position and will not stay on.
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글:
After some research, I discovered that the unit needs to be reset.
Resetting process:
Remove batteries and disconnect adapter for 15 minutes.
Reinstall batteries and reconnect adapter.
Hold reset button for 5 seconds located in the battery compartment or on the back of the unit.
(A paper clip or pin will be needed to fit into the hole for the reset button.)
의견 추가하세요
답변 1개
선택된 해법
Hi Kathy,
Sometimes the on/off switch can get a bit loose and you might need to snap it back in place. See the guide linked below!
Oregon Scientific RM318PA Power Switch Replacement
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
귀하의 답변을 추가하십시오
Kathy Rowley 가/이 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 8
전체 시간: 265
