주요 콘텐츠로 건너뛰기
J.D. Corporation's JD Razor kick scooter was released in 2000 and became the most popular kick scooter brand in Japan. The JD Razor 2000 is a special-edition kick scooter that features an added wheelie bar and linear spring suspension. Often a strap and light are included with the scooter.
How do I brake without using my wheelie bar?
Every time I try to brake on my Razor I accidentally hit the wheelie bar and send my scooter flying out from under me. It's becoming a real safety issue and makes it very inconvenient to use. I don't even need to use the wheelie bar.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
가장 유용한 답변
If you are having trouble placing your foot on the brake while using the JD Razor 2000 in a high-pressure situation such as riding down a steep hill, then it might be helpful to practice your braking motion while in a low-stress scenario such as in your driveway or on a flat street.
If you would like to remove the wheelie bar all together, then view the Wheelie Bar Replacement Guide found on the JD Razor 2000 Device Page.
If you suspect there might be an additional problem with the braking system, you can visit the JD Razor 2000 Troubleshooting Page.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Shane 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 4
전체 시간: 461
