주요 콘텐츠로 건너뛰기
2011년 상반기 모델, A1278 / 2.3 GHz i5 또는 2.7 GHz i7 프로세서.
782 질문 전체 보기
Battery replaced, old 10.95, new 11.1 V , not charging still?
Hello
I have a MacBook Pro 13" Unibody Early 2011.
Recently, the old battery stopped working so I bought a replacement from Anker (from UK).
the new battery worked fine for the initial charge it came with. But the adapter is still not charging this battery. So the LED remained green and when the battery was exhausted, the laptop shut down.
I compared the old and new batteries and found that old one had the specification:
10.95v -- 63.5wh
And the new one from Anker has :
11.1v, 5800 mah , 64 wh.
Could this be an issue ? Could this be something to do with the charge controller? or Power adapter ?
Thanks in advance!
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 1개
선택된 답변
Try resetting the SMC. Follow this Apple TN: Intel-based Macs: Resetting the System Management Controller (SMC).
해당 답변은 도움이 되었습니까?
점수 3
댓글 9개:
Hello Dan,
Thanks, but I already tried it.
I spoke to Apple, they say, could be an issue with the Logic board or charge controller. Is there a way we can check that?
Also are these batteries compatible?
Thanks.
Over time the technology used to make LiOn batteries has improved. The slight difference between the battery sets is not an issue here you are just seeing the improvement over time here. Whats important is to make sure the wiring of the set is correct. Did the supplier state clearly this was a compatible battery for your system?
True you could have a charging circuit issue here where a new logic board will be needed. But, before you go there lets finish doing the basics.
Download this little gem coconutBattery it will report the status of the battery and the charging circuit.
Thank you very much Dan!
Let me download the coconutbattery. But one thing. The laptop wont turn on when I have the battery connected. So I have to remove the battery and then I bypass SMC to turn it on. I think in that case, it can only show the status of the charging circuit.
Thanks again!
댓글 4개 더보기
댓글 달기
귀하의 답변을 추가하세요
counter 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 6
전체 시간: 647
