주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
1.5 Core Solo, 1.66 또는 1.83 Core Duo, 또는 1.83 또는 2 GHz Core 2 Duo 프로세서
Audio does not work
Hi,
The audio is grayed out in the preferences. I tried plugging in headphones, and external speakers (tested and worked fine on another mac) but they do not show up.
I have updated the system to the most current. I also Zapped PRAM hoping that would fix the problem.
I took it to Apple support and they want to replace the Logic Board. The computer works fine but no Audio.
Any suggestions? I bought it used for $420, and the logic board is around $250.
I saw this http://www.applecomponents.com/items/922...
would that work?
Thanks,
Paul
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 2개
Do speakers show up in System Profiler?
+ well stated question
댓글 달기
답변 4개
선택된 해법
Thank you,
I saw Griffen had a USB audio that bypass the mini rc jack.
No the speakers do not show in the preferences.
Thanks,
pq
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
If my answer is sufficient, could you please accept it to file this as resolved, Thanks!
댓글 달기
가장 유용한 답변
If they want you to replace your logic board, that probably means that the integrated sound card fried. So, you can try using a USB one! Some speakers already have a USB connection in with a built in sound card, but you can also get them here, make sure its Mac Compatible!
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
+ excellent alternative
댓글 달기
Greyed out speakers may mean that the sound out is "locked" in optical mode. This can happen even if you never used the optical mode.
Try put a ordinary audio plug in the sound out connection. Rotate and carefully move it in/out, left/right.
A total reinstallation of the system may help too.
Otherwise one may use a USB sound gadget. There are some fairly cheap ones on the market. Changing the motherboard seems a little bit over the hill...
이 답변이 도움이 되었나요?
점수 0
댓글 달기
If you have been inside the Mac Mini for any reason, then there is the possibility that the ZIF cable from the audio board is not properly seated. If this is the case, you get the exact same symptoms you have described.
To quote GaryObrien:
"Steps 7 and 8 in the Audio Board install (Installing Mac mini Model A1176 Audio Board) are where the solution lies.
There is a painted line on the ZIF cable. Before you close the cable lock, make sure the cable is fully inserted - the painted line will be about 1mm above and parallel to the top of the socket. Push down the clip and all should be well."
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Paul Q 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 21
전체 시간: 3,470
